Construction Solid
Construction Solid
Construction Solid
How can I creat a construction solid, that I can use as a bollean feature. Part copy (as construction) is not always a correct solution.
RE: Construction Solid
Create an assembly to better locate the parts relative to each other, then use inter-part copy to create the construction body.
--Scott
http://wertel.eng.pro
