Rotary Coupler
Rotary Coupler
I have an application where i want to feed 4 seperate water pipes and a common return to a table that is rotating on a central shaft. I require a ROTARY COUPLER that will fit on over the shaft, approx 100mm dia, and will feed the water through as the table rotates.
I did a search but could only find ones for hydraulic feed.
Any help gretaly appreciated.
Cheers,
Speedy
![[banghead] banghead](https://www.tipmaster.com/images/banghead.gif)
Cheers,
Speedy
RE: Rotary Coupler
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
RE: Rotary Coupler
My problem is that there is a solid shaft in the middle of the table.
Are there any ring type rotary couplers that allow for a shaft to fit up through the middle?
Cheers,
Speedy
RE: Rotary Coupler
http://www.scottrotaryseals.com/
RE: Rotary Coupler
http://www2.maier-heidenheim.de
RE: Rotary Coupler
ht
these guys do the gas-station type swivels:
https://www.opw-fc.com/product_category.aspx?cid=8
