ST Exhaust Pressure vs. Condenser Design Parameters
This topic came up as a point of discussion among the engineers in my company.
We are looking at suitable parameters for the steam turbine exhaust pressure vs. air cooled condenser design ambient temperature operating in a desert environment. Estimated steam flow is ~200ton/hr, 400 deg. C and 41 barA, and electricity generated ~36-40MW depending on the exhaust pressure.
I Googled and found: http://ww w.energy.c a.gov/repo rts/2002-0 7-09_500-0 2-079F.PDF It provided good case studies.
Table 4.1 (Page 4-8) presents the site conditions; Table 5-9 (pg 5-31) design parameters; Table 5-10 (pg 5-33) Operating Hours above design turbine back pressure.
My question: Without going into the detailed economics (as do not have the sale price of electricity and equipment costs right now) how can I use Table 5-9 and Table 5-10 and select a reasonable turbine exhaust pressure and achieve an optimal ACC size without always having a high back pressure and causing high back pressure alarms and/or trips?
What problems can I expect if the turbine trips too often due to inadequate performance of the ACC?
