Fire system brach pipes flow velocity
I have a custome who want to use 8" pipe to flow 2,925 us gpm. In this case the flow velocity es aproximatelly 18.78 fps.
Is this velocity aceptable?
NFPA hava a maximum velocity limits in branches pipes for foam solution and spray water system (cooling water for vertical storage tanks)?
