cryotreatment of 316L steel
Could you please give us any info on what kind of effect we would expect on a 316L liquid nitrogen straight immersion, If any? Furthermore is it possible that reheating of a 4340 steel to ambient temperature, after straight immerion to liquid nitrogen, could produce perlite/ferrite strucures? Thanks in advance.
RE: cryotreatment of 316L steel
The effects on 4130 will depend on what the structure was to start with. If it was poorly quenched or slack quenched and then cooled, you might get all sorts of strange structures.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
I dont really get it, the exact theory behind the process is seldom analyzed in the literature thus allowing a confusion behind the proper application of the process. Where is the problem with it? Which are the problems the researchers face? Is the need of speciallized equipment? No funds? What is the current trent on the cryogenic treatment, which is the next step?
I don't think there's much research on structural materials at cryogenic temperatures simply because there usually isn't much change microstructurally. The notable exception are alloys with sub-room temperature martensite finish tempeartures.
