Display Screens for SolidWorks
Hi Everyone,
The company I work for are looking into phasing out the old CRT Monitors that, due to their age, are beginning to fail.
I have been asked to asses the option of going to TFT/LCD Monitors.
My question is ... Is there a preffered standard, in terms of size/screen resolution/contrast ratio/access time, that you the community feel best works well for the Solidworks application.
I would be grateful to hear your comments.
Andy Gulliver - www.glenair.com
SW2007 SP3/PDMWorks2007 Workgroup
2.6 MHz P4 - 2GB RAM/128MB Quadro FX1400
RE: Display Screens for SolidWorks
Nicholas P. McGrew
SW 2007 SP2.1
AutoCAD 2007
- Screen size range suitable for viewing distance (in my situation 21-24", no smaller, no larger)
- Resolution: as high as possible, 1920x1200 minimum
- Decent color reproduction
- Sufficient backlight to work at 3/4 of max setting (headroom for lamp wear!)
- Decent contrast ratio @ 3/4 of max brightness
- Even lighting
- Looks / stand / cable management
Samsungs panels have allways worked well for me (both in Dell & Samsung branded monitors)
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
Chris
AutoCAD 06
Another thing is that cheesy monitors won't let you see the screen from a slight angle from normal. If you get a really big monitor, this won't work, since you'll have areas of the monitor that won't show well (especially if you're sitting close). Imagine bobbing your head around to get a better view (like looking through a microwave oven door)--not very helpful.
Monitors have improved drastically and the prices have fallen the same. But there is still a lot of lame crap out there for sale.
By the way, I use a Gateway 21" widescreen. I can plug in HDMI (if I ever want to) along with all sorts of other stuff--I threw away my TV.
http://
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
Best Regards
Andy
