Additional welding after PWHT
Dear Engineers
I have a quck question about additional wleding after PWHT
and Hydro test completely.
present situation is as follows.
In a vertical pressure vessel of ID3000mm, shell Thk 17mm
herewith, one of Internal supporter (T10mm x 50mm) was attached with 8mm fillet welding and then, this support was revomed as per client requirement.
In this condition, client ask for additional requirement as follows as per their precess requirement.
- PWHT again
- Hydrotest again.
However, this requirements is not related to ASME requirement, but only for process condition.
- PWHT again
- Hydrotest again.
RE: Additional welding after PWHT
http://www.welding-advisers.com/
Was there additional welding or grinding on the VESSEL SHELL after it has been postweld heat treated & hydrotested?
This internal stiffener was attached after PWHT and Hydro Test, and then this stifferner was removed again by Grinding.
I would also mandate an NDT (like wet fluorescent MT) of the base metal heat affected zone after local PWHT, in lieu of a hydrotest.
IF this vessel is under construction, and before ASME Code stamping, you will probably need to PWHT the base metal heat affected zone, and perform a second hydrotest to apply the ASME Code stamp.
Is it also required Local PWHT and Hydro test again.?
Process requirement is only for NACE and Sour service as we know.
I would do what your client is asking for. By welding on the vessel after PWHT, you have reintroduced residual stresses that might cause in-service cracking of the vessel.
