Autocad 2004- Cannot select viewport line
I'm using version 2004. I've got two viewports in paperspace, and in the last 20 minutes I've become unable to select the viewport to move, stretch, erase, or anything. Any thoughts?
RE: Autocad 2004- Cannot select viewport line
on which layer did you drawn the viewports? "Defpoints"? -> Thaw the layer "0" (null/zero)
Lothar
ADT 2004
In addition to Lothar's suggestions, make sure you didn't inadvertently lock the viewport.
HTH
Todd
