Outgassing of Silver Oxide, Copper Oxide, or Cusil in Vacuum
Does anyone have any data, or even general references on the outgassing of said oxides? There's plenty out there for the stability of iron oxide on iron and CRES, but nothing on the oxides I mention.
RE: Outgassing of Silver Oxide, Copper Oxide, or Cusil in Vacuum
The CRC handbook has good data on the vapor pressure of various oxides vs. temperature. It is a fairly straightforward excersize to determine, from gas kinetics, a relationship between vapor pressure and evaporation rate.
More likely is that any absorbed water (including hydrated oxides) will tend to cook off around 100 C, depending on the temperature and vacuum conditions.
http://outgassing.nasa.gov/
Not sure it covers exactly what you are looking for but its worth checking out. Hope this helps,
I would like to add out of general interest that CuO is reactive to water at room temperature. I do not know whether this is importance to your plans but I thought I should add it.
Best regards
Onno
