Catia V4 - Analysis results window not appearing
When I do an analysis in V4, I do not get the results displayed in a small box, as I would expect.  I can see the numbers if I minimize the Catia session, (in the background terminal window) but that is completely counterproductive.
I can only guess that I didn't configure something in the environment correctly. Anybody know what is the solution?
Thank you.
Catia Design|Catia Design News|Catia V5 blog
RE: Catia V4 - Analysis results window not appearing
may be you can try the  /monasc off  command
but I forgot about the environment file sorry
Eric N.
