Retaining Wall Question
Does anyone out there know if you can use Slide to predict an adequate height for a retaining wall for a soil slope--The slope is only 5 foot and is highly weathered schist--not really soil, but very unconsolidated. The wall may be overkill. Thanks.
RE: Retaining Wall Question
AFAIK, Slide is a limit equilibrium slope stability software (I have limited familiarity with it as I prefer using other software for this task) which is not entirely appropriate for the complete design and/or analysis of retaining structures. Certainly you can use it for global stability, but other failure modes are likely not well addressed using this approach.
Jeff
Thanks-
J
the wall height will depend on 1) the exposed height of the wall, 2) the slope geometry above the top of the wall, 3) the embedment depth required to ensure stability against global, sliding, overturning, bearing capacity and settlement (serviceability) failure modes. The method of analysis will also depend on the type of wall system.
Jeff
