Ballpark Calculation on shear strength from tensile strength
Hi All,
I am looking to find a "ballpark" calculation of converting tensile strength on heat treated material into a shear strength measurement. I would then test the forumla when I get the parts back.
Specifically I am looking at 1/4 diameter Pin 416 SS heat treated to Rc40. I would be perfoming a double shear test where I will put the part into a test fixture where the middle section will be pressed until breakage occurs on the both outer sections.
RE: Ballpark Calculation on shear strength from tensile strength
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Rust never sleeps
