Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site was well structured and I found what I was looking for in about 2 minutes. I am looking forward to participating with you in the future..."
Geography
SeanSweeney (Civil/Environmental)
24 May 07 8:52
When I write in a duration of 5 days I get dates from monday to monday next week. That's fine. When I do the same for 10 days I get to tuesday the following week and so on to wednesday for 15 days. Same applies if I use 1 week or 2 weeks.
There are no extra free days in between, using a standard calendar. I am using a norwegian version (Project 2003).
Why is this happening. I thought a week was 5 days (working).
Cheers. Sean.
IRstuff (Aerospace)
24 May 07 12:53
Your first answer is incorrect.  Starting on Monday 0800, 5 days ends at 1700 Friday.  You should check the actual starting TIME in addition to the DAY.
TTFN
24 May 07 13:39
Spot on - for some reason my default calendar is set from 8:30 to 16:00 - not even normal working time for Norway. Odd.
However when I create a new calendar I can't get it to give me everyday set to 8 - 17 as default (with weekends off), even though that is the default in Options - and that is using Project 2003 at home - English version.
How do I get a proper default set up? (simple questions I know)
Cheers. Sean.
IRstuff (Aerospace)
24 May 07 15:53
Does the Change Working Time in Tools not change the working time like it's supposed to?  It's also in the Options|Calendar dialog.
TTFN
25 May 07 13:39
It does but when you have to change it for a years duration it seems that there maybe a better way to do it globaly. A quick fix was to change the number of hours in a day in options to 7 1/2 which suited the mess in the default calendar.
Thanks for the help.
Cheers. Sean.
Close Box
Join Eng-Tips® Today!
Join Us             Close
