Bolted Friction Clamp Design
I am currently looking at designing a bolted friction clamp to attach a retrofitted item of controls gear to an existing subsea manifold.
I have done a literature search in the office and on the internet and discussed with colleagues the best design approach. The literature search didn't turn up a great deal, so it appears to be a from first principles design; and the discussions seemed to confirm this as each Engineer had a different approach.
I thought however I would ask the Eng-tips community if they were aware of any published guidance on the topic?
---------------------------------------------------------------------------------------------------------------------![[pimp] pimp](https://www.tipmaster.com/images/pimp.gif)
"The world keeps turning, it keeps me in my place; where I stand is only three miles from space"
Spiritualized
RE: Bolted Friction Clamp Design
Try:
http://213
h
The sections on mechanical clamps should be applicable. Part 1 design guidance, part 2 test data review.
They also have a research report on neoprene lined clamps, good for taking up some tolerance between the saddle and clamped pipe.
http://www.hse.gov.uk/research/rrpdf/rr031.pdf
Hope that helps some, anything more specific feel free.
