PDMVaultAdmin login
PDMVaultAdmin login
When reorganizing groups and users in the VaultAdmin program, the user who was the administrator is not the administrator anymore. I can't log into the Vaultadmin program since there isn't a user with that right. I've tried every other user to see if the right was passed on to them but that didn't work. I also tried reinstalling the Vaultadmin program and trying the 'pdmwadmin' user but that didn't work either. Any ideas?
Sean
Carmanah Design and Manufacturing
Vancouver, BC, Canada
www.carmanahdesign.com
RE: PDMVaultAdmin login
Have you tried to install the Vault Admin on your computer? If so and it still don't work, then you must get access to his machine and password to fix the fact you have limited rights to the vault.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
Sean
It good practice to have at least 2 if not 3 people to have admin rights to the vault as well as the person that is running the server. Incase everyone gets locked out for some reason you will always have one available.
www.scottjbaugh.com
Your PDM manual has the password in it that was setup with PDM. Try that one, maybe no one removed it yet.
The only reason I still have it in use is because people here do not know about it and I am not going to tell them either.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
Any questions, please ask.
Good luck
BW
Bradley
Sean
BW
