Convert Shelled Rectangular Block to Individual Sheets
I am drawing a blank as to the best way to do this.
I have a rectangular block that I have shelled leaving one open end so that is resembles a tank.  Now I want to convert this shelled block into individual parts for assy.  We are going to use 1/2" thick plastic sheets cut to size to assemble.  Is there an easy way to convert?
Thanks.
RE: Convert Shelled Rectangular Block to Individual Sheets
Use the Split command to create a multi-body part and then save each body as a part.
cheers
Success, THANKS!
