Common resin for pacifiers?
8
Here's another project in which I need to work with resins with which I'm not familiar.  I'm working on a pacifier design in which the nipple will be formed with a sort of silicone, but I'll also have some molded hard plastic parts.  I think I can find the silicone grade (although help on this would be great), but I'm wondering what to use for the harder structural parts.  These need to be bonded to one another (hard piece to hard piece) with solvent or adhesive and will need to withstand high temperatures (boiling in water, dishwasher heat, etc.).
Any ideas which direction to move?  I'll need something that's food-grade (minimally) and don't know what sorts of restrictions of which to be aware regarding solvents/adhesives for the rigid structural members.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
RE: Common resin for pacifiers?
I would use polypropylene and friction weld it. If not possible, polycarbonate will work for a while until the boiling water destroys it.
Noryl or PPO might also work.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks, Pat.  I have a few samples of existing pacifier products and am wondering what the harder of the plastics is--it seems to be available in bright colors (nice for this application) and quite hard (almost like acrylic, certainly much harder than PP or even PC) as well as structurally rigid.
One design has two plastic parts sandwiching a flexible silicone nipple between them.  I haven't broken this apart yet, but it appears to be adhered together (instead of solvent-bonded).
Since I commonly design plastic widgets, I'm familiar with ABS, PP, PE, certain nylons, styrene, and PC--generally the less expensive resins great for cranking out cheap products for sale to the masses.  The stuff I'm seeing in these pacifiers have me stumped--not something I've used before (almost like a hard version of PC).
Jeff Mowry
Maybe it is acrylic, but from your description, more likely polysulphone or polyarylate or Polyetheramide. These would seem excessive for the application though.
I'm familiar with none of those, so I'll check them out and see what I can find (probably expensive, eh?).
Thanks!
Jeff Mowry
Very expensive.
3
I would have thought SAN (Styrene AcryloNitrile) would be a good choice - it is used a lot for dishwasher safe containers/drinking "glasses" etc.
It is stiff, easily bonded due to the styrene content, about the same price as ABS, transparent so it takes colours well and it is easy to mould!!
It is used sometimes for blood contact parts so USP grades will be available. I would guess all the commonly used grades wil be FDA approved.
A Google will give you a squillion manufacturers and their data sheets........
Cheers
Harry
Polysuphone was looking good, but expensive.  I'll check out SAN and see what I can find.
Thanks!
Jeff Mowry
Jeff,
SAN is great for widgets!
Customers have never heard of it, even though they have a cupboard full of it!
Great for the "sell" to customers (the old adage: bull***t baffles brains - everytime!)
I'm sure you'll use it often!!
Cheers
Harry
PS At least it's better than one RFQ we had: material= "Black Plastic"- and I kid you not!
After a quick look, I'm impressed with SAN.  Might need to incorporate it much more often in my widget designing.  (I use ABS quite often already--this looks similar, but with a styrene base.)
Jeff Mowry
SAN is ABS without the butadiene elastomer phase.
Cory
SAN is an obvious choice.
It is not a resin I have ever had much to do with, so it slipped my mind.
It is hard, probably tough enough, easy to mould, reasonable price, nice glossy surface, food contact, clear base colour and can be solvent welded.
Awesome--thanks so much for the quick feedback.  I can hardly believe I've not used this stuff before.  I can think of projects for which this would have been nice.
Jeff Mowry
Other useful widget materials if you need toughness as well as  clarity are SBC's (Styrene Block Copolymer), trade names Styrolux by BASF, K Resin by Chevron Philips and others).
Tough as ABS, (No Break on un-notched impact testing), about the same or less cost, no pre drying required, easy moulding, etc.
Much used for medical stuff (USP) and by inference, FDA too.
The only drawback is the relatively low softening (Vicat) temp of around 65 Deg C. Can be mixed with crystal PS to make it a bit stiffer/cheaper, although at some ratios can get slightly cloudy depending on processing conditions. No problem if colouring though.
Cheers
Harry
Thanks, Harry, I've not used SBCs either.  Looks like it's about time to get some samples to start getting a "feel" for their uses.
Jeff Mowry
Jeff,
One of our UK suppliers has some neat comparison tables - click on the icons (as it says)! and dowload the .pdf files.
http://www.distrupol.com/
As they are distributors for many manufacturers there is a good range of products compared - I guess most of the products or direct equivalents will be sold in the US too.
Disclaimer:
There may be others too (but I have not seen one quite so neat). I have no commercial interest with the company apart from they supply to my company.
Cheers
Harry
I fully agree that SAN is a good choice, cheap, quite chemical resistant and dishwasheable. Just make sure to get the dishwasher safe grade, most of them are not.
You can think of SAN as polystyrene that's modified to be chemically more resistant. In fact the chemical resistance increases in proportion to the amount of acrylonitrile (AN) in the copolymer. In addition to the chemical resistance, the AN adds some yield strength compared to PS. In natural form it can have a yellow tinge, especially the grades with high AN and therefore good chemical resistance. Normal SAN has about 25% AN, as you get to 30% and over it becomes way more yellow. This is easily compensated using some blue dye, the manufacturer will know how to do that.
If you need SAN with higher heat distortion temperature / Vicat there are grades available for that too. They use a third monomer to achieve it. Some manufacturers use alphamethylstyrene where the extra methyl stiffens the backbone at high temperatures. Other manufacturers use N-phenyl maleimide instead, the effect is the same.
Hope that helps!
There is not any memory with less satisfaction than the memory of some temptation we resisted.
- James Branch Cabell
The SBC idea was not a bad one but I would avoid them as anything with butadiene in it will become brittle and yellow over time due to heat.
Good to know--thanks for the further insight!
Jeff Mowry
Jeff,
How's the widget design/production(!) going?
Cheers
Harry
Great, so far.  We've simplified the design concepts and will soon choose one to develop into production-engineered pieces.  We'll get some prototypes in similar materials to test and then move toward tooling.  With so many other projects on my plate, this will probably not be wrapped up until a month from now.
Thanks for asking!
Jeff Mowry
You mentioned prototypes. That made me think that I should mention that Stratasys have machines (called Titan I believe) that can make prototypes from polyphenylsulfone, polycarbonate or ABS.
Hey, that's cool--I hadn't heard they had those sorts of materials available (only ABS).  We'll probably need to create a master for the silicone part, create a mold (RTV) and then cast parts in a silicone from that mold.  For the plastic bits, I may use a new SLA resin that resembles polycarbonate for the "hard" pieces (nice resolution with this machine/material).
Jeff Mowry
Jeff,
Regarding prototyping, you may want to check out www.redeyerpm.com if you don't already have a relationship with a bureau that can do the PPSF / PC materials.  I've used them and wouldn't hesitate to do so again.
Thanks--I haven't used or heard of them before, but I'll check them out.  I do a lot of work with folks locally, but since we're about to move out of state, I'll open up my options a bit.
I like that they have the SolidWorks plug-in for getting quotes and placing orders--might be quite handy.
Jeff Mowry
