Sketch Origin is back in SW2007 EV 4.0
I have just installed the EV 4.0 service pack, and the sketch origin is visible again.  The SP. seems to run quite well - there are a lot of bugs addressed in this one.
RE: Sketch Origin is back in SW2007 EV 4.0
Nice. I haven't moved up from 2.2 for this reason. I'm also not a fan of the check in-check out Serial Number stuff that comes about when you move up from 2.2 based on a few things I read on the forum. I guess this will be inevitable.
RFUS
Same here--still on 2.0.  I'll check out the fixes before bothering after the "full" version is posted.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
We have seen a fix to really horrible large drawing performance we were having.  Supposedly it has something to do with parasolid data in the drawings.  Much improved.  We will be going to it copmany wide when it comes out.
Pete
We are running SP4.0 EV it seems to have improved our large assembly performace no end, back to 2006 opening times etc, which is good seeing as it slowed down a lot (SW didn't now why but SP4.0 has fixed it).
Woolly
