Globally selecting xyz planes in V5?
3
How do you select multiple planes in order to "no show" them all at once?
RE: Globally selecting xyz planes in V5?
a quick one....
zoom out like crazy
select planes using the paint stroke option then no show
other ways :
* use the search tools for plane then no show
* KWE : create a rule
Eric N.
3
In the power input bar. Bottom right corner type this
.*pla*
Nev
i forgot about that one...
thanks for the reminder
Eric N.
I didn't know about *pla*.  Personally, I have always typed t:plane.  Anyone know the difference and/or limitations of one over the other?
By the way, t: seems to work with just about anything. (plane, surface, line, dimension, etc...)
Catia Design|Catia Design News|Catia V5 blog
there are many ways to hide planes.  I like TOOLS + HIDE + ALL PLANES, when working with a CATPart.
I agree with Solid7; t:plane (or t=pla*) to multi-select by element Type. That's what the Help says.  Although I tried Nev's method and it works too!
There are more
I believe these to be carry overs from v4 days
.*po*  for points
.*bod* for bodies
.*lin* lines
.*set* this was a guess but it works too for geometric bodies
etc....
Nev
Is there something I need to do after entering in the input bar?  It goes in but nothing happens...
There was a macro posted on here a while back that auto hide the planes..I have lost it on my last computer change over..
Cheers
I don't know anything but the people that do.
Thanks Nev, I've learnt something here...
It's worth a .*star*
I'm trying to remember the Pre-V5 abbreviations, I think they were *pt, *ln, *crv, *sur, *pln, *axs and so on, or have I gone back to V1 !!
Your V4 abbreviations are correct.  In fact, I still find myself typing them...
Can the power input be used on assemblies, and can you run 1 command to hide all?
I use the Edit -> Search command on assemblies.  I think that you can use Power Input on Assemblies, but the syntax may be slightly different than in parts.  Rather than learn, I just use the easiest method that came along...
Edit -> Search is your best friend when doing global hide/show, in my opinion.
In addition, save your search criteria in Favorites with a name and try to use then Power Input...
Fernando
