2 channel input 2 bit binary ouput
this is for a programmable controller.
in order to select 1 of 4 available programs, we need to have a 4 position rotary switch and provide 00 01 10 11 binary output.
of course the controller supplier cannot specifically tell us what to purchase
i have looked a rotary BCD's rotary dips etc
any help would be appreciated
thanks
Paul
RE: 2 channel input 2 bit binary ouput
You could purchase a rotary switch (2 pole, 4 position) and wire up some diodes and pull-up resistors to make your own binary-output rotary switch.
something off the shelf would be ideal,
thanks anyway
Thankyou very much!
Sometimes its just the way i format my searches, i get everything but what i want.  Much appreciated
Paul
VB1BLL,
I didn't get why you think you need diodes. It's just a straight forward 2 pole 4 way rotary switch and two pull-up resistors.
Ah... The diodes are, ah, my normal fee for wiring up the, ah, two pull-up resistors and one rotary switch.  wiggle
