Body operations in Pro/E
Hello all,
Good day, here is a 2 part question:
1) Are there body operations in Pro/E (e.g. copy body, move body)?
2) Is there a way to copy a body from one part to another part (i.e. copy the topology and not the features per se)?
CATIA and SWX have these commands. I haven't found them in Pro/E yet.
Thanking you in advance,
Joseph
RE: Body operations in Pro/E
1- ProE does not have the boolean body operations, like CATIA. You cannot have multiple bodies in a single part.
2- You can copy the entire part into another part using either merge operations or: shared data->copy geometry from other model
-Hora
Hello Hora,
Thank you, the one that works best for us appears to be:
Insert > Shared Data > Merge from other model
Could not have found it without your help.
Cheers,
