Reorienting View
Reorienting View
How an existing view can be reoriented?
RE: Reorienting View
there is AFAIK no other choice other then by creating a new one an using Custom orientation
dy
Does it not combursome to rework, after dressing-up entire drawing and at-last, it is realised that base view is not in its correct orientation.
I believe, there should be solution somewhere.
If you mean reorient a isometric view then there is nothing you can do other than place a new view
I know you can do it in SolidWorks, but that uses an different method of creating drawing views.
bc
KENAT, probably the least qualified checker you'll ever meet...
They seemed to start disappearing around the same time as drawing boards when some managers began to say "We've got cad now so everything will be right anyway"
bc
