Picking dimension origin
Anybody know how to pick an intersection as dimension origin? specially when a visible edge and center-line intersects
RE: Picking dimension origin
the IntelliSketch has an Option 'Intersection' but this
will not work when dimensioning from a centerline.
A centerline is *not* a usual line it's more like an annotation.
You may dimension to/from it but it will always be a driven
dimension.
dy
Dimesioning is required in drawing mode
sure, but it will not pick an intersection between
a centerline and a visible line. Normal dimensioning
will work.
dy
