Weight in BOM, Can You Specify Units?
I have addeed a column in a BOM to show weights and I noticed a small part was 1100 while comparible parts were .5 - 1.  This was because the units of this one part was set to grams.  Is there a way to postfix whether or not its lbs or grams in the BOM?
RE: Weight in BOM, Can You Specify Units?
AFAIK, only by adding another custom property and including that in the BOM.
cheers
BTW, a UnitOfMeasure property already exists in the Property Name dropdown list.
cheers
