Surface projection in I_DEAS
Hi everybody!
I'd like to know if it is possible in I-DEAS any way to project a surface onto a plane following a direction given by you.
Thank's very much
Enrique
Thank's very much
Enrique
RE: Surface projection in I_DEAS
The command "Project" in Modeler is the only operation (other than focus) that I can think of. This command does not project an entire surface and its contour onto a plane, however, it will project all bounding edges from the surface onto a specified plane. Projection result will be those selected edges projected onto the plane as curve or edge, using a specified vector direction (normal to surface, point to point option, etc)
Rgd,
Mike Hsieh
Mike Hsieh
UGS
Anyway, surface projection is something to improve in next version of I-DEAS.
Best Regards,
Enrique Álvarez
