how to restore catia to original settings
How can I restore all CATIA settings to their default values ??
RE: how to restore catia to original settings
Another method is to simply delete the directory that contains your local settings (when you are out of CATIA, that is).
in order to avoid this change the visualization option for the vector variable = OFF
The default path is usually C:\Documents and Settings\Your user name\Application Data\Dassault Systems\Catsettings.
If you do not see application data folder that means the folder is set to be hidden. At the top of the screen go to tools/folder options/view then select show hidden files and folders.
Once you find the catsettings folder rename it to catsettings.old or something.. Reboot CATIA and see if that fixed it.
