Center-based offset of a Spline
Hey everybody :)
I've ran into a scetching problem. I am working on a cam mechanism where the cam-disk itself is mounted solid. Around it are cars running on a track in circles. Mounted with linear guides there are 2 cam-followers that run through a cavity in the top-side of the cam. These 2 cavity's over 350° the same except for the fact that one is closer to the center of the cam then the other. Nevermind the other 10°.
I'll include links to pictures of the problem at the bottom of this post.
Well, about the problem;
I've made a 2D-spline that will be used to cut-sweep the outer cavity on the top-side of the disk. Problem is I cannot just use the off-set command now to create a spline a few milimeters smaller cause it will lead to the wrong result. I've simulated the result that I want in one of the pics below by drawing a lot of lines, one each 3°.
This solution is not really a precise enough method of getting the resulting spline. And in the picture I've used a simple cam-spline while the acual spline where I need it is much more complex.
Pictures:
The spline I want a center based offset off: ht tp://img25 8.imagesha ck.us/img2 58/1177/sp inecw0.jpg
Offsetting the spline to the wrong result: htt p://img249 .imageshac k.us/img24 9/2941/off settl2.jpg
Aprox. of the result I need: h ttp://img4 41.imagesh ack.us/img 441/3158/o ffsettocen tergf9.jpg
I hope I made my problem clear. Does anyone have a tip how to create the needed spline?
Thanks in Advance,
Bouke
Pictures:
Thanks in Advance,
Bouke
Bouke Brouwers
M-Des
The Netherlands.
RE: Center-based offset of a Spline
So anything that might help would be really appriciated.
Bouke Brouwers
M-Des
The Netherlands.
