lofting a Y Duct
lofting a Y Duct
lofting a Y Duct
Hi
I'm new to these forums and what a great wealth of information reside here.
My question is with regards to Lofting a Y Duct like the sort thats used in HVAC, I can draw this with 3 circles located on 3 planes and extrude this but How about the loft feature is this possible ? I had 3 guide curves from the  each Profile to a common point in the center of the sketch, I can't figure it out.
TIA
not2fast
RE: lofting a Y Duct
I think you can make three extrusions come together, combine them, then shell.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
thanks for the reply,
Yes thats exactly what i did and shell it, So this seems  and sounds like will not work with the loft feature and 3 guide curves ?
not2fast
The loft will not work here.
The loft and sweep commands need to travel from a start point to an end point.  Multiple directions are not allowed.
Remember...
       "If you don't use your head,            idea
                   your going to have to use your feet."
I think Sweep and Shell is the way to go.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
Thank you for the replies, I will try the Sweep and shell.
not2fast
