Jet A1 Physical Properties
I am seeking information in respect of the density, viscosity, vapour pressure and bulk modulus versus temperature for Jet A1. I am aware that the properties vary depending upon the mix at the refinery however a range of values would be appreciated.
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
www.waterhammer.bigblog.com.au
RE: Jet A1 Physical Properties
The ASTM spec for Jet A1 is D1655, the British spec is DEF STAN 91-91. Either should give you all of the information your are looking for.
Reidh
