Plotting problem
Plotting problem
Plotting problem
I sure hope someone can help me here.  I am drawing a polyline with a width of 12" to indicate an area of responsibility on several drawings.  Most of the drawings are plotting properly, but 2 of them won't:  the polyline is plotting not filled in (empty), if that makes any sense.  (It appears as if it is a row of boxes.)  This is a very important project and I hope one of the fine people here can answer SOON!
I have already checked, and all the plotting settings and display settings are the exact same as the drawings that ARE plotting correctly.
Thank you SO much!
Kat
RE: Plotting problem
Hi Kat,
Make sure Fill is set to 1 or ON -
Check to be sure your VIEWDIR=0'-0",0'-0",0'-1"
Just in case make sure your viewport isn't set to remove hidden lines MVIEW, Hideplot, Off if your working in paperspace.
HTH
Todd
Thank you so much for your help.  It worked like a charm!
