Identify Fixed Relations
Is it possible to quickly identify if a sketch has been constrained properly with dimensions rather than defining with a fixed relation in order to make the sketch "fully defined".
im working with a large design tree and dont want to open each sketch in order to determine if it was constrained properly.
Is a Macro a possibilty?
RE: Identify Fixed Relations
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
I do not know of a way and I'm not sure that even API can do that ... but then I'm API illiterate.
CODE
Dim AllFeatures As Variant
Dim allRelations As Variant
Dim allChild As Variant
Dim i As Long
Dim j As Long
Dim mySketch As Sketch
Dim RelMgr As SketchRelationManager
Dim ResultString As String
Dim ChildNames As String
Dim FixedCount As Long
Sub main()
Set swApp = Application.SldWorks
ResultString = ""
AllFeatures = Empty
AllFeatures = swApp.ActiveDoc.FeatureManager.GetFeatures(False)
For i = 0 To UBound(AllFeatures)
If AllFeatures(i).GetTypeName = "ProfileFeature" Then
Set mySketch = AllFeatures(i).GetSpecificFeature
If Not (mySketch Is Nothing) Then
Set RelMgr = mySketch.RelationManager
allRelations = Empty
allChild = Empty
allRelations = RelMgr.GetRelations(swAll)
allChild = mySketch.GetChildren
FixedCount = 0
For j = 0 To UBound(allRelations)
If allRelations(j).GetRelationType = swConstraintType_FIXED Then
FixedCount = FixedCount + 1
End If
Next j
ChildNames = " ("
For j = 0 To UBound(allChild)
ChildNames = ChildNames & allChild(j).Name & ", "
Next j
ChildNames = Left(ChildNames, Len(ChildNames) - 2) & ")"
If FixedCount > 0 Then
ResultString = ResultString & vbCrLf & FixedCount & " -" & mySketch.Name & ChildNames
End If
End If
End If
Next i
MsgBox "Quantity of ""Fixed"" relations" & vbCrLf & "per sketch in this model:" & vbCrLf & ResultString
End Sub
Thanks for the vote of confidence, but I'm just a hack with an ever-growing library. handleman is the pro coder here that comes up with this stuff from scratch all the time. [smiley]
mails,
I'm curious as to why you are wanting to check sketches with fixed vs. dim'd constraints?
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
sw.fcsuper.com
Co-moderator of Solidworks Yahoo! Group
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Matt
Silicon Valley, CA
sw.fcsuper.com
A macro is definitely possible. An addin could be more useful for constant monitoring.
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
www.Tate3d.com "Right-click. It's friggin' magic!"... Jack L. Tate
FAQ376 I'm famous.
FAQ376 I'm famous.
Matt
Silicon Valley, CA
sw.fcsuper.com
RFUS
Matt
Silicon Valley, CA
sw.fcsuper.com
Matt
Silicon Valley, CA
sw.fcsuper.com
