e-transmit utility
e-transmit utility
Does this ACAD feature only work with Outlook? Can not seem to make it work w/ Yahoo.com or Verizon.net when I attach the .EXE file that I create w/ e-transmit.
RE: e-transmit utility
If you don't have one available to you then you may have to send the actual file, rather than an exe. What does e-transmit do? Is it a self-extracting zip file?
My question is why would autodesk develop such utility for clients such as you which I would think present a limited market.
Create your email from your Yahoo or Verizon and send the file.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
ctopher, changing the destination folder won't change the fact that he's creating a self-extracting executable file, which he is unable to email due to ISP limitations.
Chris
AutoCAD 06
