air port operation building conditioing
hi every one,,
i ve been asked to conditiong the operation floor & the tower of control of an air port the specification detremine the system which it is ch.water with separate chillers for tower & operation blg. at the control system dual system required if the one chiller failed do not allow operation , equipment floor to be drop out. is that suppose to use DX cooling coil + chilled water cooling coil one cover the other or it is some thing in the control system called dual system???
RE: air port operation building conditioing
