High rise VAV - multi zone
Ona 30 storey building the client want floor by floor air handling units. He wants a VAV system
However the space allocation for them is pretty small.
Can I design the air handling unit such taht it can serve 5 zones, East, west, north, south and centre zone. In other words, one fan or perhaps 2 at 50% each, delivering air into a common plenum and off the plenum, five cooling coils one for each zone. A pressure sensor in the plenum can control the fan speed for when the VAv boxes open/close?
Any body see this before?
RE: High rise VAV - multi zone
For a 30 storey building it will be more space efficient to use central plant AHU's and dedicate a central floor and roof to plant. Even though the client will loose a whole floor there will be more lettable area (ie income!) as there is no plant on each floor.
remp two common ways of handling a high rise like that in the states is either with self-contained units and a condenser water loop to cooling tower(s) on the roof, or use a central chiller plant and have air handler(s) on each floor. The tonnage and available floor space of each floor will determine the number of units. If a single unit can handle the tonnage (AHU or Self-Contained) there is no need for multiple cooling coils to meet the different zone loads. Your VAV boxes would be doing that on a zone by zone basis. Your VFD would modulate the system fan as necessary and your control system would maintain the required leaving air temp or each self-contained or AHU.
I agree you can have one AHU per floor with one coil but this is not really efficient for perimiter zone and internal zone off the same unit. if one AHU serves both you will need reheat for the centre zone becuase perimitre VAV boxes will loopk for cooler air and internal zones will look for warmer air. I want to avoid this and give each zone its own cooling coil. What you reckon.?
Based on my experience and reviewing energy modeling of typical office buildings, a very efficient system consisting of a floor by floor AHU with 100% free cooling capability, serving a straight VAV (no reheat) air distribution system, with perimeter four-pipe fan coils, can provide the best bang for the buck. Going to an underfloor air distribution system can also be another step for energy saving and better local comfort control.
However- I still think that you should be beating up the Architect to get the best envelope design you can to minimize solar gains and the usual fast-acting peak thermal transient loads around the perimeter, to make the perimeter system as minimalist as possible.
We do a lot of these buildings in the Southeastern US and we don't do any reheat in the interior zones and only reheat the exterior zones, usually using parallel fan powered VAV boxes. The keys are zoning properly and sizing the VAV boxes appropriately. For the most part your internal load will be fairly constant as the lights and computer equipment won't really change.
If you are having issues with over cooling an interior space the VAV box was sized improperly or the zoning isn't right. Your minimum position on the VAV box should be what is required to maintain the code required outside air. If you do this you shouldn't have any issues with over cooling a space without reheat.
An added note, GMcD is right on the money regarding keeping the load out of the space in the first place. Work with the architect and the owner to get the best envelope that you can. That means smaller mechanical systems and less load variation from interior to exterior zones. Be prepared to translate less load into $$'s saved.
With central AHU plant located on say levels 2,15, and roof you would probably require 12 large AHU's for a traditional VAV system compared to probably 60 (assuming 2 AHU's per floor depending on floorplate area). In either case large riser will be required for smoke exhaust which can double up as return air risers.
There are some additional costs in ductwork, but there are also signifcant saving in reduced number of AHU's (controls, electrical, piping, commissioning, maintenance, economy cycle damper)and acoustics is much less of an issue. And also want to get as much plant that requires regular maintenance away from tenanted spaces.
Depends on the client, but most large project I have worked on, the rule has always been to maximise NLA as the payback from additional rent will easily cover any additional construction costs.
Always interesting how you get 10 HVAC engineers always come up with 10 different designs, and most would would work! I've never been to the US and my only exposure to US HVAC design is in Die Hard movies, so I alway assumed all duct and grilles there were oversized (ie design code requirements for for man/terrorist/hero access) and all fans did 1 rpm?
To answer your question, there are no issues with using a common AHU for perimeter and interior zone. For winter heating you will need reheaters in the perimeter VAV boxes. You do not need any reheaters in the interior zone as the interior load is constant irrespective of the season.
The downside of one AHU per floor concept is that it is difficult to get the system to operate on an economy cycle as you need large supply/exhaust louvers on every floor. You would also need to provide a dedicated smoke extract system .But such a system has certain pluses like flexible after hours operation, better reliability etc
Requesting a decent mechanical room at each floor can actually make money sense.
Mechanical rooms are rentable floor space while shafts are not rentable, creating two large shafts will lose money for the building owner.
VAV at each floor (single duct or fan-powered), with 100% OA unit and a relief shaft is the way we design in the US nowadays.
Now you have more than one engineer thinking the same (or is it 3 engineers saying the same thing?) how often does that happen?
Seems we have leasing agents and lawyers stipulating the HVAC design concept!!
In the US, we call our drawings and specifications: "Contract documents".
lettable!!!!
