Pnuematic Instrumentation
I am looking for any good information on pneumatic instrument control systems. I am working on an offshore oil and gas application and all of the instruments are pnuematic. This is an older platform. I am not very familiar with pnuematic instruments and just looking for any free pdfs or anything that would assist in knowing more about these type of instruments. Thanks!
RE: Pnuematic Instrumentation
http://
Then look at the Fisher Wizard products.
http://ww
Yokogawa also sells knockoffs of the Foxboro products.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
rmw
http://w
Yes pneumatic instruments! The project I am working on is a compliance upgrade on a platform that was built in the mid-70's. I am new to the instrumentation side much less pneumatic instruments. The existing instruments on this platform are pneumatic. Instruments will be replaced or added as needed. Not many people I talk to have much if any experience with a total pneumatically controlled system.
Does anyone have any documentation, such as some sort of pneumatic instrument control philosophy even though it may not exactly apply to what I am doing, to use as a go-by due to my lack of experience with pneumatic control and instrumentation in general. I would greatly appreciate that!!
I appreciate the responses to links of pneumatic instruments, but I am looking for an overall tutorial, so to speak, on pneumatic control and example applications. If anyone has information on that, please post a link. Thanks for your response.
Pneumatic controls is not much different than electonic controls. Instead of 4-20 mA, they use 5-30 psi. A level controller is a level controller - sensing element, logic element, final element. Instead of a PLC, you have pneumatic controller. The application is the same.
I think you should probably study up (as you say, you are new to controls) on "control theory and implementation", rather than "pneumatic control theory and implementation" - I think it will serve you better in the end.
Albert Einstein
