Inconel Machining Specs
My shop is about to take on a quite a bit of work machining 718 inconel.  Any suggestions on milling and turning feeds and speeds whould be appreciated.
RE: Inconel Machining Specs
Based on your statement above, I would suggest you purchase a copy of ASM Handbook, Volume 16 on Machining. There is excellent general machining information for Ni-base alloys in this handbook.
Special Metals has some information on machining Inconel alloys:
http://www.specialmetals.com/documents/machining.pdf
Also cutting tool manufacturers like Seco Carboloy, Valenite, etc. have new generation tools and coatings that can improve the machining performance of high-strength nickel-based alloys.  You may find some of the archived articles at the following site helpful:
http://www.productionmachining.com/articles/index.html
http://www.ctemag.com/archived_articles.php
http://metalworking.penton.com/
Carpenter Technology Corp., Reading, Pennsylvania has, or had, a wonderful little book on machining various stainless and nickel alloys. Don't know if it is still in print.
