Executing UG macros in batch mode.
Hello!!!
Does anybody knows how to execute a .macro file without open UG???
The purpose of that is to run a .macro periodically in batch mode using a CRON, that's why I need to have a .bat or any other executable file to execute it...
Thank you for any help....
RE: Executing UG macros in batch mode.
Why not start an instance of UG in the .bat file before you start the macro?
Not sure if you can run a macro from a bat file command line but you can definately do this via grip and journals.
Not sure if that helps.
Mark Benson
Aerodynamic Model Designer
