whats up with lines that cant be trimmed or extended?
when sketching sometimes ill run across a line that cant be modified.  happens usually when the line is obtained via convert entities command.  I know its probably something really simple and I run into this kinda thing every once in a while so i thought id ask this time.
thanks in advance.
RE: whats up with lines that cant be trimmed or extended?
Two words for you... POWER TRIM.
Look it up in the HELP MENU.
It will change your life.
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
www.Tate3d.com "Right-click. It's friggin' magic!"... Jack L. Tate
FAQ376 I'm famous.
I love power trim.  But not even power trim can mess with these lines.
Do you know the Ctrl-pick extension trick for lines to meet at a point...???
Then you got different lines than I have EVER gotten...
Try to first grab & drag the endpoint off, then see if you can do anything with it.
Dutch... can you expound on that trick a little?
FAQ376 I'm famous.
Draw a vert and hor line that don't meet. CTRL pick and HOLD end of one line and drag cursor over other desired line. VOILA...if thats too vague lemme know.
Dave
ill try that next time.
I did exactly that (I think) & nothing happened...?
Maybe it's a version thang.
FAQ376 I'm famous.
Addendum: Pick extend line first...lol
Nope... tried it every way and then some...
FAQ376 I'm famous.
You don't need to use the Ctrl key for that ... and you can Extend and Trim using either tool by dragging and dropping.
cheers
no guys, the extend or trim simply dont do nothing to the line.  I know how to use the extend command......
WHen the convert entities command is used, you basically get three constraints, one to each end point and 1 on the profile.
Once you grab one of the converted end points and move it off its reference, you can then use the trim/extend command on it.
Remember...
       "If you don't use your head,            idea
                   your going to have to use your feet."
Chances are the lines are at different elevations, have you checked that yet?
Zuccus
the line im trying to extend is in a regular sketch, not a 3d sketch. and i cant post the file sorry its kinda top secret.
Have you tried meintsis suggestion yet?
cheers
Yeah, i went to the external references list and deleted all of them, still wont budge or extend or nothing.
External references?
You have an open sketch and have used the "convert entities" command to create a line in the sketch.    correct?
Can you then drag the converted endpoint?
What about using the "split entity" command on the line, delete a segment, and then extend the remaining segment?
Remember...
I just realized that when I answered the question from the OP, I thought I was in the autocad forum
Sorry
uGlay, you must have a converted entities spline.  Right?  No trim for you.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe transcends reason.
One other note:
If you ae using the "convert entities" command on multiple edges on once, common endpoints will be constrained to each other.
Remember...
