SHEET METAL BUG?
SHEET METAL BUG?
I'd like someone to confirm this for me, before I report a bug...
Create a simple sheet metal part.
In the CONFIGURATION MANAGER, right-click the DEFAULT config.
Select PROPERTIES.
Select CUSTOM PROPERTIES.
Under PROPERTY NAME, pull-down DESCRIPTION.
Under VALUE/TEXT EXPRESSION, pull-down THICKNESS.
With your cursor at the end of: "Thickness@Default@Part1.SLDPRT"...
Type something like "SHEET" (any text will do).
See what you get for EVALUATED VALUE.
Does this work right for you?
Thanks...
Select PROPERTIES.
Thanks...
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
www.Tate3d.com "Right-click. It's friggin' magic!"... Jack L. Tate
FAQ376 I'm famous.
RE: SHEET METAL BUG?
Try the same thing with MASS or MATERIAL & see if your results compare.
Thanks again...
FAQ376 I'm famous.
Yes, I would say that is a bug.
If I double-click the dinemsion of the feature: "Thickness@Sheet-Metal1@@Default@Part1.SLDPRT"... then I get what I want.
Thanks for pointing that out handleman.
...no bug then.
FAQ376 I'm famous.
So an ER instead of a Bug report then.
