Unlinked dimension question
Say I model a 2” cube and then create a drawing for it. When I slap a dimension on one of the sides, the dimension is going to read 2”. But I want to over-ride the text with something else for whatever reason, and I’m prompted with the warning about the tolerance no longer being live. The dimension text is no longer linked to the model, which is expected. Question is, do these ‘over-ridden’ dimensions have a name such that I can go into doc properties and give them a special color so that next time I open the drawing they’ll stand out?
Chris
Chris
RE: Unlinked dimension question
I am sure you are aware that using overridden dims is NOT a recommended practice, and that is probably why an option is not available to colour them.
Think about this.
Draw your part at maximum material condition with a plus nothing tolerance +.000 and the minus tolerance of what ever.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
Magnitude The Finite Element Analysis Magazine for the Engineering Community
