Pump Governor and self operated regulators
Can anyone help me understand the difference between Pump governor and self operated regulator?
RE: Pump Governor and self operated regulators
However, let's make a few assumptions. Perhaps this is a steam driven pump. A pump governor could be a mechanical device where the centripedal force moves a weight outward with mechanical linkage to reduct the steam flow. Perhaps the self operated regulator is a valve that uses force on the diaphragm. These can be pressure reduction to maintain the downstream pressure or pressure relieving to limit the inlet pressure.
So this would be straight proportional control, and for every flowrate there would be a slightly different pressure associated.
Now in the modern world we would put a pressure transmitter on the pump discharge, run the signal thru a PID controller, outputting to an air-operated control valve on the steam line to the turbine. With a properly tuned loop, then the pressure would be dead-nuts on all the time AND your instrument techs would be dealing with familiar equipemnt...it's just a pressure control loop when it's piped up this way.
