Details of integration points
If somebody can tell me how to get the locations at the integration points of an element and stress and strain at each of them (inside a perticular element not the closest to a node as given in the manual), it will be very helpful.
Thank you very much.
RE: Details of integration points
1- the locations of the integration points are known once the nodal locations are known and also of course the element formulation. This info I think you can find in the Theory Manual.
2- This is a thing you can ask directly to ANSYS (plot/list stresses at integration points directly transfered to the nodes), but I never tried to "*GET" this with the APDL command.
yes, I believe so. The dimensionless form should be the most useful, I think, but it depends how you prefer to handle coordinates' matrices...
