Rolled-back state?
Rolled-back state?
I keep getting the message when I open an assembly that one or more components are in a rolled-back state and if I wish to roll them forward.
I haven't been able to locate the rolled-back parts to keep from getting that message.
Does anyone know of a quick way to find them?
Soil
Soil
RE: Rolled-back state?
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
www.scottjbaugh.com
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
www.Tate3d.com "Right-click. It's friggin' magic!"... Jack L. Tate
FAQ376 I'm famous.
Solution Id: S-09722
Question:
A rollback and adding a cut feature of a component can result in a Non-responsive status of an assembly. Why? The following error message displays, 'One of the components of this assembly is in rollback state. The assembly is inaccessible now.’
Answer:
This is a known issue, and a workaround exists to resolve the issue.
1. Go to Window > Close all, and save all files when prompted.
2. Reopen these files and they will work properly. <However, there should be no rebuild message when re-open the assembly file according to the message before saving it.>
This issue has been identified and reported to the development team on SPR 333035 ("Rollback and adding cut feature of component result in Non-responsive status of its assembly.")
www.scottjbaugh.com
1) Select the Open icon or File -> Open
2) Check Advanced (also unchecked Lightweight but not sure if that is needed)
3) Select the file to Open
4) Click OK on the first dialog that shows up to "Open currently select configuration"
And then voila! it pauses at the file that is rolled back!
The reason the workaround that Scott found in the KB didn't work for me was that it was a sheet metal part that was funky... it wasn't apparent what was wrong but I unsuppressed the flat-pattern, rolled it back behind the flat-pattern, rolled it forward and then suppressed the flat pattern again, saved and voila!
www.scottjbaugh.com
So, is there a KB article on this issue with sheet metal parts?
