UW 11(A)(5)(b) verse UW11 (b)
|Per Section VIII Div 1. can anyone in laymens terms explain the difference between the two and when and when not to use them.
UW 11(A)(5)(b) verse UW11 (b)UW 11(A)(5)(b) verse UW11 (b)(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: UW 11(A)(5)(b) verse UW11 (b)
thread794-174111: UW-11 interpretation
http://ww
There are three kinds of people in this world; those who can count and those who can't.
Properly applying UW 11(A)(5)(b) allows the use of a 1.0 weld efficency in the head and shell. The long welds must be 100% radiographed or a seamless shell used. Each vessel must be radiographed.
Paragraph UW 11(b)[RT3] is for spot radiograph and the one spot on 50 feet of weld applies. A joint efficency of 0.85 is used for the shell and head. This may result in a lot less inspection for a UW 11(b) vessel.
I am presently working on a project that requires radiograph per UW 11(A)(5)(b). Nobody is sure why it is required so I asked an AI if he knew why it would be specified? He said he wasn't sure other than the fact that he rarely sees RT2 [UW 11(A)(5)(b)] specified any more. It's usually full radiograph (RT1) or spot (RT3).
Also, since the ASME Code is difficult to interpret, the pictures that CodeJackel references are relied on more to specify radiograph requirements.
Hope this helps?
In short, paragraph UW-11(a)(5)(b) radiography MUST be separate shots and do not contribute to the UG-116, RT-1,2,3 and 4 rules for stamping.
The UW-11(a)(5)(b) RT shot is used as a "QUALITY" shot or in another term, a statistical “quality check” of the
ability of the welder to deposit sound weld metal. One reason for the quality shot is because the stresses acting on the Category B welds (circumfirential) do not control the design for an internal pressure only load case.
'In short, paragraph UW-11(a)(5)(b) radiography MUST be separate shots and do not contribute to the UG-116, RT-1,2,3 and 4 rules for stamping.'
This coment may be confusing. The radiographs taken per UW11(a)(5)(b) do indeed influence the appropriate stamping.
As an example the spot radiographs on round seams when combined with the complete radiography applied to long seams result in RT-2, as the spots taken on long seams when combined with spots on round seams taken per UW11(a)(5)(b) can result in RT-4.
To answer your original question... No, it can't be explained in simple terms.
Joe Tank
