UEL subroutine - linking problem
Dear All,
i tried to run an analysis job linked with a user subroutine (written in fortran) source file, with
Abaqus 6.6 on a windowsx86-32 platform.The files are example files provided with release.
I get in abaqus command window this messsage:
C:\Temp>abaqus job=ueldynam user=ueldynam.for interactive
ABAQUS JOB ueldynam
ABAQUS Version 6.6-1
Begin Compiling ABAQUS/Standard User Subroutines
5/21/2007 12:27:27 PM
End Compiling ABAQUS/Standard User Subroutines
5/21/2007 12:27:28 PM
Begin Linking ABAQUS/Standard User Subroutines
Creating library standardU.lib and object standardU.exp
LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; us
e /NODEFAULTLIB:library
End Linking ABAQUS/Standard User Subroutines
Begin Analysis Input File Processor
Run pre.exe
ABAQUS License Manager checked out the following licenses:
ABAQUS/Standard checked out 5 tokens.
<13 out of 18 licenses remain available>.
5/21/2007 12:27:36 PM
End Analysis Input File Processor
Begin ABAQUS/Standard Analysis
Run standard.exe
5/21/2007 12:28:24 PM
C:\Temp>
and I get a error dialog box of standard.exe stating "This application has failed to start because MSVCR80.dll was not found. Re-installing the application may fix the problem."
Then after closing error dialog box that's complete message in my abaqus command window:
ABAQUS JOB ueldynam
Run pre.exe
Run standard.exe
ABAQUS Error: The executable C:\ABAQUS\6.6-1\exec\standard.exe
aborted with system error code 309.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run ABAQUS that you
used when the problem occurred. Please contact your local ABAQUS support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
ABAQUS/Analysis exited with errors
C:\Temp>
Any idea as to what the problem could be?
Please, answer me. Any suggestion could be very useful for my work. Thanks a lot in advance for your helpfulness
_________________________________________________
alorenzom
merengue82@libero.it
ABAQUS JOB ueldynam
Run pre.exe
Run standard.exe
C:\Temp>
ABAQUS JOB ueldynam
Run pre.exe
Run standard.exe
C:\Temp>
alorenzom
RE: UEL subroutine - linking problem
I create an abaqus env file in my local directory copying that in site directory and adding usub_lib_dir variable and adding \NODEFAULTLIB:LIBCMT.LIB in the tuple value of parameters link_sl and link_exe. My local abaqus env file appears like this:
# System-Wide ABAQUS Environment File
pre_memory = "256 mb"
standard_memory = "256 mb"
standard_parallel = ALL
mp_mode = MPI
mp_file_system = (DETECT,DETECT)
mp_environment_export = ('ABA_CM_BUFFERING',
'ABA_DDM_DEBUG',
'ABA_ELP_SURFACE_SPLIT',
'ABA_ELP_SUSPEND',
'ABA_MEMORY_MODE',
'ABA_MPI_MESSAGE_TRACKING',
'ABA_MPI_VERBOSE_LEVEL',
'ABA_PATH',
'ABA_RESOURCE_MONITOR',
'ABA_RESOURCE_USEMALLINFO',
'ABAQUS_LANG',
'ABAQUSLM_LICENSE_FILE',
'ABQ_CRTMALLOC',
'ABQ_DATACHECK',
'ABQ_RECOVER',
'ABQ_RESTART',
'ABQ_SPLITFILE',
'ABQ_XPL_WINDOWDUMP',
'ABQ_XPL_PARTITIONSIZE',
'ABQLMHANGLIMIT',
'ABQLMQUEUE',
'ABQLMUSER',
'CCI_INITIAL_EXCHANGE',
'ABAQUS_CCI_DEBUG',
'CCI_RENDEZVOUS',
'DOMAIN',
'DOMAIN_CPUS',
'FLEXLM_DIAGNOSTICS',
'FOR0006',
'FOR0064',
'LD_PRELOAD',
'MP_NUMBER_OF_THREADS',
'MPC_GANG',
'MPI_PROPAGATE_TSTP',
'MPI_SOCKBUFSIZE',
'MPI_WORKDIR',
'NCPUS',
'OMP_DYNAMIC',
'OMP_NUM_THREADS',
'PAIDUP',
'PARALLEL_METHOD',
'RAIDEV_NDREG_LAZYMEM')
compile_cpp=['cl', '/c', '/nologo', '/W0', '/MD',
'/TP', '/GX', '/DNDEBUG', '/DWIN32', '/DTP_IP', '/D_CONSOLE',
'/DNTI', '/DFLT_LIC', '/DOL_DOC', '/D__LIB__', '/DHKS_NT',
'/DFAR=', '/D_WINDOWS', '/O1', '/I%I']
compile_fortran=['ifort', '/c', '/Gm','/nologo', '/include:%I']
link_sl=['LINK', '/nologo', '/INCREMENTAL:NO', '/subsystem:console', '/machine:I386', '/NODEFAULTLIB:LIBC.LIB', '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:LIBIFCOREMD.LIB', '/DEFAULTLIB:LIBIFPORTMD.LIB', '/DEFAULTLIB:LIBMMD.LIB', '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib', '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib', '/NODEFAULTLIB:LIBCMT.LIB', '/FIXED:NO', '/dll', '/def:%E', '/out:%U', '%F', '%A', '%B', 'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib', 'advapi32.lib']
link_exe=['LINK', '/nologo', '/INCREMENTAL:NO', '/subsystem:console', '/machine:I386', '/NODEFAULTLIB:LIBC.LIB', '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:LIBIFCOREMD.LIB', '/DEFAULTLIB:LIBIFPORTMD.LIB', '/DEFAULTLIB:LIBMMD.LIB', '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib', '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib', '/FIXED:NO', '/LARGEADDRESSAWARE', '/out:%J', '%F', '%M', '%L', '%B', '%O', 'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib', 'advapi32.lib']
# If you are attempting to compile C++ programs using ABAQUS/Make without a
# Fortran compiler installed on your machine, uncommenting the following
# link_exe command may help resolve any link errors.
# link_exe=['LINK', '/nologo', '/INCREMENTAL:NO', '/subsystem:console', '/machine:I386', '/NODEFAULTLIB:LIBC.LIB', '/DEFAULTLIB:OLDNAMES.LIB', '/NODEFAULTLIB:LIBIFCOREMD.LIB', '/NODEFAULTLIB:LIBIFPORTMD.LIB', '/NODEFAULTLIB:LIBMMD.LIB', '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib', '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib', '/FIXED:NO', '/LARGEADDRESSAWARE', '/out:%J', '%F', '%M', '%L', '%B', '%O', 'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib', 'advapi32.lib']
standard_parallel = SOLVER
mp_mode = THREADS
import driverUtils, os
graphicsEnv = driverUtils.locateFile(os.environ['ABA_PATH'],'site','graphicsConfig','env')
if graphicsEnv:
execfile(graphicsEnv)
else:
raise 'Cannot find the graphics configuration environment file (graphicsConfig.env)'
del driverUtils, os, graphicsEnv
abaquslm_license_file="@100.100.100.7"
doc_root="http://www.labmec.unical.it/v6.6"
usub_lib_dir = "C:\Documents and Settings\alorenzom\Documenti\HC3FEM\AbaqusHC_fetchedAbaqusFiles"
I execute next procedures and I get next messages in my abaqus command window:
>abaqus make library=ueldynam.for
ABAQUS JOB ueldynam.for
5/22/2007 1:43:26 PM
Creazione della libreria standardU.lib e dell'oggetto standardU.exp in corso.
ABAQUS JOB ueldynam.for COMPLETED
>abaqus job=ueldynam interactive
Old job files exist. Overwrite? (y/n): y
ABAQUS JOB ueldynam
NOTE: "usub_lib_dir" has been added to User Subroutine library path.
5/22/2007 1:45:20 PM
Run pre.exe
5/22/2007 1:45:21 PM
Run standard.exe
5/22/2007 1:45:22 PM
ABAQUS Error: ABAQUS/Standard Analysis exited with an error - Please see the
message file for possible error messages if the file exists.
In my msg file I found
***ERROR: USER SUBROUTINE UEL MISSING
Has anyone any idea for solving my execution problem?
