Plastic Compatibility With Turbine Lube Oil
Can anyone refer me to a guide to plastics compatibility with hydrocarbon and synthetic based turbine lube oils? I've tried DuPont and GE websites with not much luck. Waiting to hear back from DuPont Engineering. Thanks!
RE: Plastic Compatibility With Turbine Lube Oil
http://www.compasspublications.com/guides.htm
HTH, dogtop
Pipe materials compatability with the media transported is not the only element of piping system design.
The ASME B31.1/B31.3 piping codes contains cautions and restrictions about transporting flammable liquids in plastic piping systems.
Also, I believe the NFPA codes have similar restrictions.
My opinion only...
-MJC
