Assembly Cut Question
I have a question about using the Extrude tool in assemblies for Pro/E WF 3. I have been sent an assembly and the Extrude tool has been used to cut half of the assembly away to create a cross section view. Don't ask me why this method was used instead of using the x-sec tool, I'm at a loss as well. What I need to know is if there is a way to "undo" the cut. I need the whole assembly back and I'd rather not reassemble the whole thing.
Thanks in advance.
Thanks in advance.
RE: Assembly Cut Question
Fighter Pilot
Manufacturing Engineer
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
Fighter Pilot
Hello all,
I think I am having the same problem as msutton. Basically, I don't see assembly features in the feature tree. I can see them in the graphics. Anyone know how to "show" assembly features in the feature tree?
Cheers,
Choose to display Features and Suppressed Objects, And even Annotations so you can easily erase those Hole Notes.
After Setting your settings you can save them to a file proe defaults to tree.cfg as name but I usually save them with names like tree_feat_note_sup so I can have several settings customized to what I want to See.
To save the settings Use Settings, Save Settings and to open saved settings there is an Open Settings File option.
The config.pro option is model tree
mdl_tree_cfg_file X:\FULL\PATH\TO\tree_config_name.cfg
Michael
Mike
Thank you Michael, Settings (above feature tree), Tree Filters worked.
