355kW Laurence Scott Electromotor
Great Forum - wish I had found it ages ago!
Does anyone know of a used machinery dealer that might have a 355kW LSE motor? I am looking for a 4 pole, 440V, 355/630 frame spare for a centrifugal pump.
RE: 355kW Laurence Scott Electromotor
Where are you? I guess you are looking for something fairly local?
  Sometimes I only open my mouth to swap feet...
Guess I should have mentioned Australia somwhere in my query!!
Have you tried the L-S website? http://www.laurence-scott.com/ there is an on-line form on this site that can be filled in but be quick as they are currently in administration.
Hoxton,
thread237-187224: Laurence Scott & Electromotors
Sad news - hopefully the receivers can keep it as a going concern.
LSE
LSE has now been bought by the ATB group so will continue, I guess. ATB own Schorch so how much will be moved to Germany in the future remains to be seen.
Spare frame
Unless you have a drawing of the original motor your only chance is to approach them direct
Bronob,
Motorspert is correct ATB have bought LSE and from what I have been told after a short transitional period their products will continue to be manufactured at the LSE factories.
As you are in Australia I recommend you contact your local Toshiba office as ATB manufacture products for Toshiba. They will be able to send your enquiry through as soon as the transition is completed.
