remove SiO2 layer which occurs naturally on the Si3N4 powders
I want to remove SiO2 layer which occurs naturally on the Si3N4 powders. But I do not want to use HF because it is not safe. Is it possible to remove SiO2 by using any other acids/bases?
Any information is appreciated. Thanks for all.
RE: remove SiO2 layer which occurs naturally on the Si3N4 powders
TTFN
