ACAD Conversion from cu.in to gallons
Can any convertion program (but not with lisp) be integrated in ACAD so that instead of reading volume units in cu.in.,these units can be automatically converted to gallons when I do a mass properties check under the inquiry command?
RE: ACAD Conversion from cu.in to gallons
or 277.4196 for uk gallons ?
http://joshmadison.com/software/convert/
http://mechcad-insider.blogspot.com/
"The fear of the Lord is the beginning of wisdom"
